Forums >> Revit Building >> Technical Support >> What's the Point of the Membrane Layer
Mon, Nov 11, 2013 at 8:22:52 AM | What's the Point of the Membrane Layer
pshalliday
Can anyone tell me what the point of the membrane layer is in walls when they dont display in plan or section. If you want to show a vapour barrier in plan/section you have to use a different layer or just draw it in using detail lines - so what do the membrane layers actually do?
(Revit 2013)
Mon, Nov 11, 2013 at 8:39:07 AM | What's the Point of the Membrane Layer
It schedules in BIM.
Mon, Nov 11, 2013 at 9:26:40 AM | What's the Point of the Membrane Layer
pshalliday
who produces vapour barrier schedules? why not make it visible ?
Mon, Nov 11, 2013 at 9:36:12 AM | What's the Point of the Membrane Layer
How can it show, it is hidden in the structure and it has no thickness.... It's like paint except it is located at a defined place.
Why argue?  If you don't like it, just don't use it.
Mon, Nov 11, 2013 at 11:01:44 AM | What's the Point of the Membrane Layer
BTW - You can also tag the material in section views.
Mon, Nov 11, 2013 at 5:11:55 PM | What's the Point of the Membrane Layer
archigrafix
5 Stars: 4 Votes
There are many types of membranes, some have a few milimiters thickness, and it's therefore relevant for 1:1 - 1:5 details. We use this linetype: http://www.archigrafix.com/revit-membrane.html
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Errors using Membrane Layer: zero / non-zero thickness
Wed, Aug 7, 2013 at 6:08:50 PM
Kenoting a Membrane Layer (0" thickness)
Sat, Feb 12, 2011 at 12:23:27 PM
Zero thickness wall layer
Mon, Mar 30, 2009 at 7:22:16 AM
Tapered roof/slab
Thu, Aug 7, 2008 at 12:31:38 PM
Tensile Membrane Structures [ 1 2 ]
Fri, Oct 1, 2004 at 10:43:14 AM
21
Page generation time: 0.6096
