Forums >> Revit Building >> Technical Support >> Surface Pattern Wrap Roof Question
Sat, Nov 9, 2013 at 10:28:17 AM | Surface Pattern Wrap Roof Question
jmd3d
Revit LT 2014
I opened the Comercial_Sample_Project and noticed that the Roof surface pattern wraped eaves.  I created a roof of the same type by extrusion and by footprint and the pattern does not wrap the roof.  Any ideas why this is happening?
Thanks.
Tue, Nov 12, 2013 at 5:24:44 PM | Surface Pattern Wrap Roof Question
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You can use the material 'Paint' tool and 'tab' to select the fascia. You can also 'tab' to select the line pattern and nudge it to move the pattern and try to get them, to line up. Not sure if LT is any different however . . . .
Edited on: Tue, Nov 12, 2013 at 5:25:50 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Hiding Surface Pattern For Specific Wall Material
Thu, Feb 21, 2008 at 10:47:29 AM
Extruded roof - surface pattern displaying incorrect
Wed, Sep 8, 2010 at 10:00:11 AM
Revit 2015, Conical Roof Surface Pattern Twist
Wed, Apr 22, 2015 at 8:57:44 AM
problems with metal roof surface pattern
Tue, Mar 10, 2009 at 2:02:45 AM
Page generation time: 4.7770
