15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> scaling camera view on sheet
4 Posts No Rating |
I'm using Revit 2014. I used to be able to scale camera views on sheets by clicking on the view, but now that option is not coming up. Was there a change? Can we still do that?
Click on the view boundry - Size Crop on the menu.
4 Posts No Rating |
Thank you. Some bottons had disappeared, and after I restarted Revit, the size crop button re-appeared. About 3 times a day I have to restart Revit because commands or command bars start vanishing, or a tutorial window ghost won't go away. Is this a memory problem? Is there a fix.
The problem is either you have not installed the latest update or it is your video card.
- You need update 1 - update 2 was supposed to be out yesterday as well
- Video Card - Turn off hardware acceleration.
Re-positioning a camera in plan when the view is already on a sheet? |
Tue, Nov 20, 2012 at 12:48:09 PM
saving 3d view camera angle |
Fri, Dec 30, 2016 at 7:16:40 AM
Materials in a camera view |
Mon, Mar 25, 2013 at 8:17:41 AM
Render goes ok but when i change angle - the render is black |
Tue, Oct 20, 2015 at 1:12:58 AM
TAGGING CAMERA VIEWS |
Fri, Jul 23, 2010 at 7:34:18 AM
