14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Door not cutting joined wall
13 Posts No Rating |
So I have a regular bathroom wall and I added a 4' high ceramic tile wall. I joined the walls and put a door in. Problem is door is not cutting through the tile wall, only the gyp. bd. wall. If I extend the tile wall above the door, it cuts through it fine, but that's not what I need.
I could've sworn this worked properly before. Any ideas?
System: Revit 2014 (update release 2) on Quad-Core Thinkpad w/ 64-bit Win7 & 8Gb Ram. |
Ok, so this is weird. I took the tile wall up to ceiling and the door cut throught the tile wall. Then, just for the sake of trying, I brought the tile wall incrementally down to 4' and lo and behold the door is cutting it fine.
Happy that it's working, but would like to know how to make sure it doesn't create problems in the future. Ideas?
Thanks
Do you have the latest updates installed on Revit? That is usually the best place to start.
Yes I do have the latest. Just went thgough this with my last post. Everything is currently up to date.
Revit 2018 - still lthe same issue - and still the same solution. Thank you!
Join the walls again.
That's why I laugh at artificial intelligence. Or maybe guys at autodesk already know how to make doors to cut all walls encountered but they leave it for future releases for comercial purposes.
door opening cutting parallel wall |
Mon, Sep 15, 2008 at 2:54:10 PM
window not cutting joined roof |
Mon, Mar 6, 2017 at 4:23:50 PM
door not cutting wall |
Mon, Apr 6, 2015 at 10:24:32 AM
Opening Tool in JOINED Walls |
Thu, Jul 22, 2010 at 6:18:37 AM
Wall Base/ Wall Sweeps and Door "Clipping/Cutting" RVT 2014 |
Fri, Jul 8, 2016 at 12:35:14 PM
