Forums >> Community >> Newbies >> constraints not satisfied... driving me crazy
Wed, Nov 6, 2013 at 10:35:33 AM | constraints not satisfied... driving me crazy
kerberg
So i have such a simple adaptive model here and i cant seem to wrap my head around the logic of the parameter and why every time i it gives me a constraint not satisfied complaint. !
I have four adaptive points. I make a reference point, moved forward in the z, drew a diagnol between that moved point and on that diagnol drew a point . then I made 3 panels from these points... when i try to parameterize it it gives me the constraint not satisfied !
any help is appreciated Thanks -Ethan
Thu, Nov 7, 2013 at 9:47:06 AM | constraints not satisfied... driving me crazy
cganiere
cganiere Avatar
Create only reference plans or reference points first. Then set up your parameters. Test the references. Once the references work then add your adaptive points.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Thu, Nov 7, 2013 at 1:11:39 PM | constraints not satisfied... driving me crazy
kerberg
thanks for your reply! I'm sitting down tonight to rewatch some tutorials http://vimeo.com/50769957
and understand the proper order of the workflow better! Thanks again-Ethan
Constraints Are Not Satisfied when opening file - Revit Architecture 2008
Wed, Aug 27, 2008 at 9:46:30 AM
Constraints not Satisfied
Thu, Jul 2, 2009 at 6:12:44 AM
"Constraints are not satisfied"
Wed, Jun 7, 2006 at 8:17:24 AM
Constraints r not satisfied
Sat, Aug 23, 2008 at 1:27:36 PM
Arraying Louvre Problems - Constraints not satisfied
Mon, Nov 22, 2010 at 7:52:26 AM
Page generation time: 0.0498
