10 Users Online (8 Members):
Forums >> Revit Systems >> Technical Support >> IFC export/import and "Identity Data"
1 Posts No Rating |
Hello.
I wonder if anybody can help me with following: is it possible to populate "Identity Data" fields via IFC import?
This is what I am trying to achieve:
1) I have created simple Revit project with single Model (in my case I choose one of standard Revit Families - some kind of cooking range). At this point I can see that there are some values in "identity Data".
2) I export this project to IFC (using updated exporter and updated export UI).
3) I import resulting IFC file back to Revit. At this point, every single field in "Identity Data" is empty.
I can see that Revit did export values for "Identity Data". There is IFCPROPERTYSET "Idenity Data" and it has number of IFCPROPERTYSINGLEVALUE associated with it. It seems that the problem lies on "import" side.
Any comments/suggestions will be highly appreciated.
Cheers,
Andrei
3D DWF export in Revit 2009 does not export identity data |
Thu, Nov 19, 2009 at 12:01:43 PM
What is de difference between "Void From" and "Properties>Identity data>Void&qu |
Thu, May 3, 2007 at 3:46:46 PM
Identity Data |
Thu, Oct 6, 2005 at 10:21:03 PM
Revit Identity Data export to Navis |
Tue, Aug 30, 2022 at 6:23:11 AM
IFC import intoRST2010?.. |
Fri, Mar 26, 2010 at 2:07:17 PM
