Forums >> Revit Building >> Technical Support >> LEVELS
Thu, Feb 16, 2006 at 7:50:08 AM | LEVELS
SVA1
the level lines is not visible in the sections and elevations, how to solve this?
Thu, Feb 16, 2006 at 8:56:20 AM | RE: LEVELS
latemore
latemore Avatar
3 Stars: 2 Votes
maybe first check your visibility settings in the views. have you turned them off? also it is possible to individually hide or show annotations in a view. if you run your mouse over the elevation, are they ghosting in?
Thu, Feb 16, 2006 at 2:04:40 PM | RE: LEVELS
LastSpartanStanding
If after checking that Levels visibility is on in Visibility Graphics and they are not hidden by using Hide Annotation in View, you may have encountered a bug from Release 7. When the ability to control Grids and Levels in 2D or 3D was added Level indicators would sometimes move far out into space and become invisible. You may be able to find them by Zooming to Fit and looking very closely for a faint empty circle which represents the grips in the 3D version of the Level indicator. It can sometimes be difficult to find them, but they are there somewhere.
Thu, Feb 16, 2006 at 5:43:36 PM | RE: LEVELS
eldados
eldados Avatar
4.5 Stars: 8 Votes
create a scope box around your model, go to section and make sure the box is tall enough(pass your model) click on one of your level lines, right click and select all instances, go to properties and down the dialouge box pick your scope box. all the levels should appear and allign with the box. you can delete the scope box once done... HTH
Integrator
KarelCAD
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:19 PM
Page generation time: 0.1922
