Forums >> Revit Building >> Technical Support >> Detail Callout Issues
Wed, Oct 30, 2013 at 4:11:38 PM | Detail Callout Issues
ChChChChela
ChChChChela Avatar
I'm working in Revit Architecture 2013.  I'm having issues with my detail callouts showing on my Plans and Enlarged Plans.  I've checked Visibility Graphics and the templates and "Callout" is checked.  I've also checked the detail I've created and checked "hide at scales coarser than." They were showing at one point and now they disappeared on the plan and I can't create any new detail callouts.  They are still showing in my Detail views.  Am I missing something?
Thanks in advance.
Thu, Oct 31, 2013 at 7:28:29 AM | Detail Callout Issues
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"I can't create any new detail callouts"
Are you getting an error when you try or it just doesn't work? Do you have all of the updates installed?  Did you check to see if they were just hidden (by clicking on the lightbulb not in VG)?
Thu, Oct 31, 2013 at 7:32:58 AM | Detail Callout Issues
Do you have your updates installed ?  You don't say.
Try a new plan and see if they work.  If not, then it may be your system or a corrupted file.
Thu, Oct 31, 2013 at 7:59:34 AM | Detail Callout Issues
ChChChChela
ChChChChela Avatar
All my updates are installed and I checked my lightbulb.  When I try to create one, I get this message:
"None of the created elements are visible in Floor Plan: 1ST FLOOR - NEW View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
I will see if making another plan will help.  I am JVing with another Architecture firm, so I will see if they changed a setting, because it worked earlier that day.
Thu, Oct 31, 2013 at 10:05:59 AM | Detail Callout Issues
FWelliot
I would check to see if you have filter actvated that is hiding them.  Other than that, they might have been deleted.  Do a save as and change name and back up the old file to a version where they were visable and see what the view settings are and recreate those condtions in the save as file.
Thu, Oct 31, 2013 at 10:40:49 AM | FWelliot
ChChChChela
ChChChChela Avatar
Quoting FWelliot from 2013-10-31 10:05:59
I just got off the phone with them.  They did have a filter on it hiding all details that weren't on sheets.  Thanks!
Detail callout vs. Floor plan callout
Mon, Nov 2, 2009 at 11:03:39 AM
Detail callout head size variable?
Wed, Mar 6, 2019 at 4:26:35 PM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:09:24 AM
How do I show a detail callout in more than one view?
Thu, Oct 7, 2010 at 1:22:09 PM
callout only head
Tue, Mar 26, 2013 at 7:09:20 AM
Page generation time: 0.3549
