Forums >> General Discussion >> Revit Project Management >> Revit 2014 to Artlantis 5
Wed, Oct 30, 2013 at 2:14:09 PM | Revit 2014 to Artlantis 5
Canhatelier
Hello... I've successfully installed Artalntis 5.0.2.3! I work with Revit Architecture 2014, and i tried to install the plugin Revit_2014_to_ATL5_Win64. The main issue is that, after successfully installation of plugin, when i open Revit, it doesn't show on the ribbon (Addins Tab). Any ideas what's wrong with the plugin? Or if someone is running ok with this plugin? Cheers
Thu, Oct 31, 2013 at 7:20:15 AM | Revit 2014 to Artlantis 5
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is the plug-in saved in the correct directory?  If it is then you are better off contacting Artalntis and asking them.
Fri, Nov 1, 2013 at 12:02:00 AM | Revit 2014 to Artlantis 5
Canhatelier
I have only done the setup.exe..and it was saved on the default folder..wiitch folder should it be?
Fri, Nov 1, 2013 at 8:14:47 AM | Revit 2014 to Artlantis 5
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The default folder is C:\ProgramData\Autodesk\Revit\Addins\
Tue, Nov 5, 2013 at 7:16:21 PM | Revit 2014 to Artlantis 5
Canhatelier
There is no option to choose the directory or folder when i install artlantis plugin, how to change it?
Tue, Jul 14, 2015 at 10:00:56 AM | Revit 2014 to Artlantis 5
jimex
hi, I’m using Revit 2015 and trying to render it with Artlantis 5, but it too slow, since i used to work on Arhcicad 16 and render it with the same Artlantis which was much faster... please help… what I’m I doing wrong.
Artlantis
Tue, Apr 8, 2014 at 6:43:56 AM
Artlantis 6.5 for Revit has arrived!
Wed, Feb 1, 2017 at 10:48:31 AM
Revit Building 9.1/Artlantis
Thu, Apr 16, 2009 at 3:10:05 AM
PLEASE HELP! Revit + Sketchup intol Artlantis
Sat, Jun 7, 2014 at 6:26:28 AM
13
artlantis renderer 2.1 + revit 2010
Wed, Jun 17, 2009 at 10:22:58 AM
11
Page generation time: 1.2941
