25 Users Online (23 Members):
Forums >> Revit Systems >> Technical Support >> pipe dimensions
hi all. i'm using revit 2014. i have a problem that i can't find a solution to. my pipe tag it grabing the offset from the wrong place. i have the pipe set to bottom justified, and the pipe tag is set to bottom. however the dimension the tag shows is to the center of the pipe. this can cause major problems for installing. is there a way to get the tag to show the bottom of pipe elevation? or the bottom of the insulation?
Try to learn at least one new thing every day |
A spot elevation defaults to the center but you can move to the bottom or top.
What tag are you talking about?
i'm using a Pipe Size - System - Elevation Tag. that i modified. if you open the tag, and look at the properties of the lable it shows that it is set to bottom.
Do you mean the bottom indicator in the tag? That is not the pipe bottom.
What did you use to create your tag? The default invert tag reads the invert but points to the center of the pipe. Check out your tag by placing a spot elevation tag in an elevation and see if the two read the same number.
I would be careful using a "Tag" to get the bottom of pipe. The parameter that most people use when they are trying to have a "1-tag-fits-all" to incorporate the size,system, & elevation is the "Invert elevation" for the label within the tag. The issue with this is the invert elevation does not take into consideration pipe thickness. I believe the industry switches the O.D. @ 14" and up. see attachment.
Trim HSS Round pipe into another HSS Round pipe |
Tue, Apr 3, 2012 at 4:39:45 AM
Pipe Accessories and Pipe Type parameter |
Tue, Dec 27, 2011 at 11:25:39 AM
Pipe Branch Takeoff/Gain |
Fri, Feb 26, 2016 at 12:29:37 PM
Pipe Sizes |
Thu, Jan 22, 2009 at 5:56:11 PM
Array/group pipe connectors |
Wed, Jul 14, 2010 at 4:59:44 AM
