Forums >> Revit Building >> Technical Support >> Pattern files
Wed, Feb 15, 2006 at 9:49:39 PM | Pattern files
geoffy
I have a pattern file I would like our students to use, where are the .pat files kept??? I can't find them anywhere (sheesh!!!!)
AutoCAD & Revit TAFE teacher from regional Australia
Fri, Sep 15, 2006 at 8:49:34 PM | RE: Pattern files
aQiL
Hi The Revit .pat files are kept in CPuhrogram FilesAutodesk Revit Building 9Data
Sat, Sep 16, 2006 at 5:11:34 PM | RE: Pattern files
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've moved and keep all our pat files in the actual network library. Much easier than locally on each workstation. It doesn't particular matter where they are kept, revit on references these files when you are loading a new pattern. HTH.
Regards,
Chris.
Pattern (.PAT) Files
Mon, May 3, 2021 at 4:51:04 PM
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Pat files corrupt
Thu, Jan 22, 2009 at 3:20:12 PM
Patern Files
Wed, Nov 16, 2005 at 2:53:56 AM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Page generation time: 1.0184
