Forums >> Community >> Newbies >> Flat Concrete Tile Roof
Mon, Oct 28, 2013 at 1:35:17 PM | Flat Concrete Tile Roof
rcobbjr
3.5 Stars: 3 Votes
I want to add a roof object to a model showing the finish roof material as flat concrete tiles. I have an image of the concrete tiles (see attachment) and I want create a rendering of the model with the concrete tile pattern. I took the Roof Asphalt Shingles material and duplicated it. I then changed the name to Roof Flat Concrete Tiles. I modified the image for the asphalt roof and changed it by adding the concrete tile image. I applied the new "material" created to the Finish 2 layer in the roof object. Any other suggestions on how I may be able to set the roof object  properties so it will render with the concrete tiles?
I would also like to be able to generate a section of the roof (eaves detail) showing the flat concrete tiles in section (similar to the eave detail attachment). Any suggestions on how to do that in concert with the first inquiry?
Is it possible to add "sweep profile" to a roof as it is to a wall? Is it possible to apply the concrete tiles as a mass objects to sweep along the roof object separately? I am trying to exhaust all possibilities.
Mon, Oct 28, 2013 at 1:44:50 PM | Flat Concrete Tile Roof
Let us see your material settings.
Mon, Oct 28, 2013 at 1:52:37 PM | Flat Concrete Tile Roof
rcobbjr
3.5 Stars: 3 Votes
Images of Flat Concrete Tile material settings.
125454_Flat_Concrete_Tiles_1.JPG125454_Flat_Concrete_Tiles_2.JPG125454_Flat_Concrete_Tiles_3.JPG
Mon, Oct 28, 2013 at 2:34:18 PM | Flat Concrete Tile Roof
Did you set up the sample size?  I don't see a pattern assigned under graphics to control your model pattern - you need that as well.
Mon, Oct 28, 2013 at 2:47:59 PM | Flat Concrete Tile Roof
rcobbjr
3.5 Stars: 3 Votes
Yes I did set that up. I set it up using the same pattern that I attached to the first message for this inquiry.
Mon, Oct 28, 2013 at 2:55:28 PM | Flat Concrete Tile Roof
So show us the image that is similar to mine.....
Tue, Oct 29, 2013 at 9:07:46 AM | Flat Concrete Tile Roof
rcobbjr
3.5 Stars: 3 Votes
I think I got it. I pulled an image of the flat concrete tiles. The image is 5 tiles wide and 9 to 10 tiles high. I did research on the tiles that says they are 13" wide and approximately 14" exposed with a 3" overlap. I used this information to set the scale which is 5'-5" wide and approximately 10'-10" high. This gives an approximate accurate number of tile courses on the roof. Attached are the images requested as far as the settings for the roof materials. I also attached an image of the model with the flat concrete tiles installed.
Please advise on how to improve or correct the model.
Tue, Oct 29, 2013 at 9:15:48 AM | Flat Concrete Tile Roof
Did you assign a model hatch pattern in the graphics tab?  This pattern is associated with the model pattern so that you can adjust it.
You can read about this alignment in your HELP.
Aligning the Surface Pattern on a Model Element
and this:
Aligning the Render Appearance to the Surface Pattern
Tue, Oct 29, 2013 at 10:25:17 AM | Flat Concrete Tile Roof
rcobbjr
3.5 Stars: 3 Votes
I did add the model pattern. I created a new pattern for concrete tiles and set the cross hatch pattern with 13" wide vertical lines and 14" between horizontal lines. Interestingly the graphic image does not match the lines but this is probably a scaling issue.
Tue, Oct 29, 2013 at 10:31:52 AM | Flat Concrete Tile Roof
I take the time to post the sections you should read in your help - you should at least take the time to read them.
Roof Tile Material..... Monier Life Tile
Mon, Oct 31, 2011 at 2:15:22 AM
Three-Dimensional Tile Roof
Sat, May 30, 2015 at 10:43:29 PM
Barrel tile roof by extrusion
Fri, Jan 14, 2011 at 1:10:17 PM
flat roofs
Mon, Mar 7, 2005 at 8:38:24 AM
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:00 AM
Page generation time: 4.6827
