Forums >> Revit Structure >> Technical Support >> Material Takeoff for insulation??
Mon, Oct 28, 2013 at 9:38:05 AM | Material Takeoff for insulation??
moffatt
moffatt Avatar
5 Stars: 2 Votes
I get that I can make a material takeoff for general things in my design but if I wanted to find out how much insulation there would be in my house model is it possible to make a takeoff for that?
Mon, Oct 28, 2013 at 9:47:41 AM | Material Takeoff for insulation??
Is your material a separate layer or simply batt insulation in a cavity?  You really should have told us.
  • Obviously, if it is a sheet good applied as a layer, then just take that off in a material schedule.
  • If it is batt insulation in a cavity, take off the area of your exterior walls.  If metal studs, then that is your area.  If wood studs, then you will have to factor appropriately.
Mon, Oct 28, 2013 at 9:57:10 AM | Material Takeoff for insulation??
moffatt
moffatt Avatar
5 Stars: 2 Votes
it isn't a layer i was just hoping there was a tool that took the information from the wall type and calculated the insulation amounts needed
Material Takeoff
Mon, Apr 27, 2015 at 7:32:15 AM
Ceiling Material Takeoff
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff issue
Mon, Oct 25, 2010 at 3:48:35 PM
Sheathing Material Takeoff
Mon, Apr 25, 2011 at 7:01:06 AM
Wall Material Takeoff vs. Wall Quantity Takeoff for material description
Mon, Mar 15, 2010 at 1:57:00 PM
Page generation time: 8.1463
