Forums >> Community >> Newbies >> Making wall from pallets
Fri, Oct 25, 2013 at 5:14:21 AM | Making wall from pallets
Mirabelle
Hi
My name is Mirabelle. I'm 24 and I'm a last year belgian architecture student.
I recently discovered how to work with revit but it's already my favourite programmeSmile.If I make some mistakes in writing english please forgive me, because I'm not a verry good writer.
At the moment I'm designing a school completely out of pallets. I made one pallet as a model. And I was wondering if I could make a wall out of this pallet? In the edit assembly I want this wall construction: 144mm pallet + 30mm polyurethane+ 144mm pallet(with insulation in it). If anybody could help me that would be most welcome! Greetz Mirabelle
Fri, Oct 25, 2013 at 5:38:28 AM | Making wall from pallets
4 Stars: 205 Votes
Just duplicate and rename a wall, then goto properties and change the wall like you want.
Fri, Oct 25, 2013 at 5:53:59 AM | Making wall from pallets
Mirabelle
Hi,
I did this but I can't give the wall the appearance of a pallet.
The wall remains grey.
Fri, Oct 25, 2013 at 7:19:15 AM | Making wall from pallets
What you are showing us is the render appearance.  If you are looking at a shaded view, you will need to set that color as well.  You also need to set an image for your material.
A better method for family and family element selection. More like ADT pallets
Wed, Jan 26, 2005 at 5:51:18 PM
Making wall families
Wed, Aug 15, 2007 at 11:51:42 AM
Making your first wall type assembly
Wed, Apr 26, 2006 at 3:51:42 PM
Making a Custom Wall w/ Hrz. planks on Studs
Mon, May 25, 2009 at 7:31:13 PM
Problems creating this wall
Mon, Feb 8, 2010 at 3:49:13 PM
Page generation time: 0.7615
