Forums >> Revit Building >> Technical Support >> Tag Suite and Maintain Rooms
Thu, Oct 24, 2013 at 2:35:44 PM | Tag Suite and Maintain Rooms
benlink
I need each of my offices to be tagged and show square footage, occupancy, name, etc, but then, on top of that, I need a suite, which will include all the offices and reception.  If I just turn off all the room bounding properties of each wall, this obviously doesn't work for the individual rooms.
So, in short: Is there a way to maintain the individual rooms in a suite, but create a tagable suite that includes all the rooms as well?
Thanks.
Fri, Oct 25, 2013 at 2:07:02 AM | Tag Suite and Maintain Rooms
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
how about trying with area plan?
you can use area tag for suite of all rooms. and you can also create tags for each rooms in area plan.
otherwise, you have to make two differnet levels for one level, and use room seprators instead of walls, that makes possible you want.
I just wrote a blog post about this issue.
http://plevit1.blogspot.kr/2013/10/rooms-tag.html
and there is a tutorial video.
want more?
You can get more tips at Enjoy Revit
Fri, Oct 25, 2013 at 2:09:05 AM | Tag Suite and Maintain Rooms
ronmalit
5 Stars: 3 Votes
HI
is this thread solved? if still not, have you tried the area plan?
** dont be mad, i dont have much... i am homeless
Fri, Oct 25, 2013 at 2:10:31 AM | Tag Suite and Maintain Rooms
ronmalit
5 Stars: 3 Votes
woahh missed by 2minutes..lol
Fri, Oct 25, 2013 at 1:02:12 PM | Tag Suite and Maintain Rooms
benlink
Dingohot,
Thanks for your detailed response and video!  This does leave one issue, though: I need this space to schedule within the Level 01 sections of some schedules.  I'm excluding the individual rooms in these instances, too.  With this method, I can't get the suite to fall anywhere but under the new level name in the schedules.
Any suggestions?
Sat, Oct 26, 2013 at 12:11:00 AM | benlink
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting benlink from 2013-10-25 13:02:12
Dingohot,
Any suggestions?
I just thought Tagging was the most important thing for you at your first question.
if not, there are some other ways to achieve your goal. if making schedue is important, you can just use information parameters of room model. and at plan view, i don't think taging is the best option. if i were you, i'd try with room legend to explain zones which include mutiple rooms.
actualy, i'm not sure what's your purpose which matters everything. there're various ways to express or describe design of buiding in Revit, i'm quite sure there must be the best way to make what you really need.
Edited on: Sat, Oct 26, 2013 at 12:16:54 AM
want more?
Mon, Oct 28, 2013 at 7:59:17 AM | Tag Suite and Maintain Rooms
benlink
Ah, well, I need to tag it and schedule it.  The end goal is to have an occupancy/ egress schedule which treats a group of offices as one suite.  This needs to be represented in the plan, as well.
I'm not sure what you mean by "information parameters of room model."  Is there a way to group the rooms? I know I can create a column parameter in the schedule to group rooms by some alphanumerical designation, and perhaps that's my best answer for scheduling.
I would however like to be able to tag the suite, as you've illustrated, but have it schedule under the right floor.
Thanks for all your help.
.blc
Mon, Oct 28, 2013 at 8:26:21 AM | Tag Suite and Maintain Rooms
If you add a suite name (or number) parameter to each room, then these can be grouped in the schedule.
Mon, Oct 28, 2013 at 8:58:38 AM | Tag Suite and Maintain Rooms
benlink
WWHub,
Right, that's what I meant by "create a column parameter in the schedule to group rooms by some alphanumerical designation"
I think this method, in unison with dinghot's method for tagging will work.  I'll just have to tell the schedule to ignore the extra level.
Thanks all.
.blc
two seperate rooms but with one room tag
Thu, May 22, 2008 at 6:56:07 PM
Tag Rooms in ceiling plan
Mon, Sep 9, 2013 at 9:43:05 AM
BIM Manager Suite
Wed, Jul 2, 2014 at 7:38:50 AM
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:55 AM
Room Tag issue
Mon, Aug 31, 2009 at 9:21:14 AM
Page generation time: 1.5595
