Forums >> Revit Building >> Technical Support >> Is there a way to exclude what a void cuts into?
Wed, Oct 23, 2013 at 2:28:41 AM | Is there a way to exclude what a void cuts into?
Skyhook
Hi All -  I'm working on editing an existing family in Revit MEP 2010. I've used a void extrusion to cut a hole in my face panel but this void is also cutting into the new group geometry that I want to fill the hole.  Is there a way to exclude what objects my void is cutting into? Is there another way I should be cutting the hole in the face panel?
Thanks for your help!
Wed, Oct 23, 2013 at 9:44:19 AM | Is there a way to exclude what a void cuts into?
I don't know what's what in your model.  I would assume you have a void to cut the wall.  Is that what you are talking about?  Voids in families set to cut a solid will also cut all joined solids.  Does that halp you come up with an answer?
Wed, Oct 23, 2013 at 10:32:58 AM | Is there a way to exclude what a void cuts into?
Skyhook
The geometry in the hole is not joined to the large solid, it is a separate model group dropped into the new hole. When I ungroup the geometry, it still cuts the pieces as shown.
Wed, Oct 23, 2013 at 10:42:00 AM | Is there a way to exclude what a void cuts into?
Do you really mean goup?  Why would anything be grouped?
Did you try a nested family?
Material not painting on some void cuts.
Sat, Feb 11, 2012 at 2:24:10 PM
Family Void cutting through two elements in a project?
Tue, Sep 11, 2012 at 2:55:56 PM
Can't get VOID to cut my countertops... [ 1 2 ]
Fri, Feb 25, 2011 at 1:41:44 PM
17
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
exclude from masking region
Sat, Jul 27, 2013 at 5:16:34 AM
Page generation time: 0.3785
