12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> linked CAD linework
I am having trouble with the linework reading properly. I link a CAD dwg. to my revit model and once its in my model the linework doesnt read as it does in autocad. I have dashed or hidden lines in my CAD plan and once I link it in revit they show up as solid. I am thinking it has something to do with the LTscale in autocad?
Linetypes are set by your import template. Read this topic in your HELP:
Setting Line Weights for Imported DWG or DXF Files
You can over-ride these settings in VG of any view.
its not the lineweight that I am having trouble with its the linetype. for instance, I am linking a CAD drawing from a consultant and in the CAD drawing there are some hidden or dashed lines. and they read as so in autocad. once I link the CAD file into revit and view it in revit the hidden or dashed lines read as solid lines.
47 Posts No Rating |
Look under the 'imported objects' tab in your object styles and make sure the linetype for the layer your dashed lines are on is set correctly.
so I checked in the imported oblects tab under object styles. the lines in question are listed as IMPORT-file name|DASHED. that line pattern name in the same as listed in CAD.
Change it to a Revit linestyle that suits your needs.
Problem exporting view with linked CAD file |
Wed, Mar 18, 2009 at 3:46:34 PM
Constraining to linked CAD file |
Thu, Apr 4, 2013 at 3:09:14 AM
Linked in CAD text |
Fri, Aug 16, 2019 at 8:25:10 AM
Export from Revit To CAD with RELATIVE linked files |
Wed, Nov 29, 2017 at 11:00:35 AM
revit freezing and not responding when cad file linked |
Fri, Feb 6, 2015 at 11:24:56 AM
