Forums >> Revit Building >> Technical Support >> View(s) Deleted After Sync ?
Mon, Oct 21, 2013 at 9:59:10 AM | View(s) Deleted After Sync ?
exavier820
Revit MEP 2013 on Citrix server
After doing some modifications to piping and adding annotations, the file was synced. Continued working and the file would freeze when adding additional text. Closed the program after sync'ing, reopend by pulling a new local, the view had been removed from the sheet amd deleted (annotations with it obviously), but the model piping modifications remained. The WEIRD thing is that in the thumbnail view prior to opening it showed the sheet I was working in with the view still on the sheet.
This has happened on more than one occasion. Not indcluding someone accidentally deleting something, has anyone else ran into a similar situation? It seems to be isolated to MEP.
Rolled back the file from the previous sync and everything to that point was recovered.
Thanks
Mon, Oct 21, 2013 at 10:01:32 AM | View(s) Deleted After Sync ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We don't know what Revit version or build you are on but make sure you have the latest updates installed.
Mon, Oct 21, 2013 at 10:22:41 AM | View(s) Deleted After Sync ?
exavier820
It states at the very beginning of the post MEP 2013 on a citrix server. What other information should I include?
Mon, Oct 21, 2013 at 10:30:14 AM | View(s) Deleted After Sync ?
In Revit, click on the down arrow next to the question mark and pick about.  Now you will see what updates you have (if any) right under the build number.
Mon, Oct 21, 2013 at 10:36:48 AM | View(s) Deleted After Sync ?
exavier820
Ah ha, thank you
Build 20121003_2115 (x64)
Update Release 2
 I see there is a release 3 for 2013. I will install that and see if the glitches continue.
Thanks for the speedy responses gentlemen.
Edited on: Mon, Oct 21, 2013 at 10:40:27 AM
Edited on: Mon, Oct 21, 2013 at 10:41:11 AM
Bring back deleted element.
Tue, Aug 4, 2015 at 3:34:02 PM
Revit Worksets won't sync
Tue, Apr 23, 2013 at 9:52:14 AM
Section Title View deleted can not recover
Tue, Jun 9, 2015 at 7:48:40 AM
Central Model File locations - clouds Revit Arch 2015
Wed, Dec 6, 2017 at 10:10:53 AM
Deleted Roof Level View
Mon, Mar 1, 2010 at 10:04:04 AM
Page generation time: 0.5366
