17 Users Online (15 Members):
Forums >> General Discussion >> Revit Project Management >> Stairs
Would someone please be able to explain why the handrail on my stairs is not running parallel to the nosing’s? The top flight is the only one where the handrail is running parallel??
See extract attached.
You gave us an image but no data. Did you set the slope or did you let the host set the slope?
I have found the problem, end with riser was not ticked in the properties under edit stair.
Wrapping stairs |
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs |
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above |
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post |
Sat, Apr 16, 2011 at 9:27:29 AM
Help with stairs |
Fri, May 4, 2018 at 7:32:59 AM
