Forums >> Revit Building >> Technical Support >> Printing elevations with shadows.
Mon, Oct 21, 2013 at 2:34:28 AM | Printing elevations with shadows (Rvt 2013)
alb1no
Hi there Smile,
I am trying to print elevations with shadows but for some reason they turn out messed up.
The titleblock is missing, dimensions are missing etc.
I've been told that this is because of the cast shadows option. I've turned it off and everything is OK.
My question is, how do you guys print elevations with shadows?
Edited on: Mon, Oct 21, 2013 at 2:38:38 AM
Mon, Oct 21, 2013 at 7:56:28 AM | Printing elevations with shadows.
Do you have all 3 of the 2013 Revit updates installed?
Tue, Oct 22, 2013 at 3:45:53 AM | Printing elevations with shadows.
alb1no
Yes, I am working with Revit Architecture 2013 Educational version. All of the 3 Releases are installed.
I am not the only one having this issue.
Fri, Nov 1, 2013 at 3:39:51 AM | Printing elevations with shadows.
alb1no
I couldnt find any solution for this problem. Sad
If anywone else is having this, my workaround is to trace over the shadows with a transparent hatch (grey solid fill).
It takes some time but looks great.
Printing Shadows in .pdf file - Revit 7.0
Wed, Dec 22, 2004 at 9:16:23 AM
help with shadows on elevations
Fri, May 16, 2008 at 1:52:59 PM
Printing with Shadows on and PDF
Wed, Jun 3, 2009 at 1:54:17 PM
Help with shadows
Wed, May 28, 2008 at 7:00:59 AM
V7 Shadows
Wed, Dec 8, 2004 at 5:41:46 PM
Page generation time: 0.7782
