Forums >> Community >> Newbies >> Fill in Space between floors/levels
Fri, Oct 18, 2013 at 1:31:33 PM | Fill in Space between floors/levels
rcobbjr
3.5 Stars: 3 Votes
I am working on a BIM that has several floors. I have the base constraint and top constraint set for the walls. There space between the top constraint (top plate) on one floor and the base constraint (finish floor) for the next floor. This space is for the joists and subfloor. Any suggestions on how to "fill in" the space between floors to "cover up" the joists so they are not exposed to the elements? See attachment.
Fri, Oct 18, 2013 at 1:47:02 PM | Fill in Space between floors/levels
See my response to a similar question here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=31610
defining a space with multiple offset floors (MEP2011)
Tue, Jun 29, 2010 at 12:30:50 PM
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:19 PM
How do you treat split levels or minor level changes?
Mon, Jun 26, 2006 at 10:40:01 PM
section mark across many levels
Mon, Aug 13, 2007 at 10:07:26 AM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
Page generation time: 1.7638
