Forums >> Revit Building >> Technical Support >> Materials not plotting in elevation
Wed, Oct 16, 2013 at 5:55:22 PM | Materials not plotting in elevation
AnejoDave
I have a project with a bunch of curtain walls being used as chainlink fences.  The system panel does not plot it's crosshatched pattern when transparency is turned on.
Any ideas what's going on?  This is in Frustration 2013
Use "Hide in View" and you're a nazi terrorist who takes the last beer
Wed, Oct 16, 2013 at 8:52:50 PM | Materials not plotting in elevation
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
One idea, and its a temporary work around, but have you tried plotting to PDF, and then plotting to paper with the PDF?
I've heard of this error before and I can't for the life of me remember where it was, revitforum.org or augi.com forums.
Its fixable.  It might be a crosshatch model vs. drafting lines issue.  Have you tried using the actual chain link material for the individual panels?
Also, you could probably use a repeating line based family instead of a curtain panel system for the chain link fence.  6'-0" x 6'-0" with a post, right?
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Mass plotting transparent
Wed, Jan 16, 2008 at 9:42:15 AM
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Plotting HELP!!
Tue, Nov 14, 2006 at 3:13:10 PM
Plotting
Fri, Apr 28, 2006 at 8:31:02 PM
Page generation time: 0.5481
