22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Trying to make a non ADA ramp but always have problems with railings, need help!
3 Posts No Rating |
the error showing up is "Cannot create continous rail geometry", is there anyway to possibly shut off the rails and add them in later separately?
*note - its not a steep ramp but does not follow the 30' ADA standard, this may change in the future, it also has a few curves which I presume may be the culprit
Yes you can create railing separately after you complete your ramp.
24 Posts No Rating |
I always run into this problem with Modeling and curves. Sometimes revit just cannot create a sweep when the curve is too small/sharp. Like teafoe said, you can create it later seperately.
In Solidarity |
3D ADA Ramp |
Thu, May 1, 2008 at 9:45:11 AM
ADA Ramp |
Mon, Jun 20, 2005 at 6:21:23 PM
Railing at ramp and stair |
Fri, May 29, 2009 at 7:40:59 AM
railings arain... |
Tue, Oct 20, 2009 at 2:17:20 PM
Railings floating above the ramp? |
Wed, Aug 13, 2008 at 11:02:33 AM
