23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> rendering
17 Posts No Rating |
I applied paints on walls but when I render it, paints are not showing. The only thing I'm getting is plain color for all of the textures.
Any idea how to tweak this?
There is not enough information for us to help you. Attach an image of your problem. You say all your getting is plain color well what are you suppose to be getting? Why are you painting things insead of appling a material to them? What did you paint?
I applied paints on some of the walls, models, windows and doors. But when I render it, those elements that I applied paints are not showing on the end results of render.
Please see attached.
Thank you!
Are you using phasing?
Textures from a distance will not always show - I believe that is your problem here. Do a zoomed in area and render that to see what you have.
teafoe5: Yes I'm doing Phasing. I already switch the phasing graphics overrides to "By Category" but still I'm not getting it right.
WWHub: Still not showing.
Thanks!
Then you have not applied a material with a texture. Remember, texture and hatch patterns are two different things.
Edited on: Tue, Oct 15, 2013 at 1:23:02 PM
I applied paint not texture. My question is how do I make those paint shows up in my render.
You are obviously not following the correct process. Either study some more or create a project that only has a wall and a door in it that you have painted and let us look at it. Make sure you purge all and compress before trying to attach it.
Realistic Rendering [ 1 2 ] |
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ] |
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue |
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009 |
Mon, May 11, 2009 at 4:32:50 PM
help with rendering! |
Wed, Aug 10, 2016 at 10:47:17 PM
