Forums >> Revit Building >> Technical Support >> Accessing Revit 2013 File - Issues
Sat, Oct 12, 2013 at 1:43:38 PM | Accessing Revit 2013 File - Issues
ChChChChela
ChChChChela Avatar
My firm is working on a Revit file that has set up worksets and a central file. Three employees have their own local file to access the central file. When one tries to work on the file, an error message keeps appearing:"File is being accessed by someone else and is not available. Click cancel to stop the current operation and try again later or wait for the file to become available."This happens often, even when we try to save. We even tried to create a new local and central files and the issue is still present. How can we solve this?
Sun, Oct 13, 2013 at 8:13:26 AM | Accessing Revit 2013 File - Issues
abdulameercp
Edited on: Thu, Oct 17, 2013 at 12:31:25 AM
Mon, Oct 14, 2013 at 7:43:03 AM | Accessing Revit 2013 File - Issues
You write "...Three employees have their own local file to access the central file...."  I would hope that all users only work in a local file.
Check your update frequency under the Revit R pulldown - options.  If you have a slow system this can help if it is less often.
Mon, Oct 14, 2013 at 8:44:08 AM | WWHub
ChChChChela
ChChChChela Avatar
Quoting WWHub from 2013-10-14 07:43:03
Sorry, I copied and pasted that from an email I sent to an IT person where I had to spell it out for them.
But thanks, I will try that.  Also, this issue has just started happening once our IT guy updated our Windows Server.  I'm still on Windows XP while my other co-workers are on Windows 7.  I'm wondering if it has something to do with it.  I read something about it here:
http://revitclinic.typepad.com/my_weblog/2011/11/file-is-being-accessed-by-someone-else-and-is-not-available.html
Accessing Central File Issues
Fri, Sep 28, 2012 at 7:12:14 AM
12
Is anyone having ssues with piping in Revit MEP 2013
Mon, Nov 12, 2012 at 11:50:44 AM
Revit 2013 running slow - anyone have the same issues?
Sat, Mar 1, 2014 at 1:37:56 PM
Issues Upgrading Revit File
Fri, Jul 12, 2019 at 4:26:06 AM
Revit 2013 Color Schemes Issues In a central file with linked buidlings
Sun, Aug 25, 2013 at 8:55:04 AM
Page generation time: 3.5552
