Forums >> Revit Building >> Technical Support >> Mirroring
Fri, Oct 11, 2013 at 6:11:11 PM | Mirroring
jordanjoyful
So guys. I had to mirror my whole project to keep it from falling of a cliff. Mirroring went fine, but now my section lines are not where they belong in all my views, and they are upside down in others! Whats worse is, I go into fix them and the others flip around. What am I doing wrong here?
Sat, Oct 12, 2013 at 1:12:02 AM | Mirroring
CDWdavid
5 Stars: 5 Votes
You should mirror the model only, then redo all annotations and re-compose your views.
Try to copy that project with a new name, delete all annotations, then open the old file with the new one side by side, using copy and paste to re-place all annotations.
Or you can turn off all annotations, mirror the model, then turn all annotations on, move them to the correct locations.
Edited on: Sun, Oct 13, 2013 at 10:29:04 PM
Mon, Oct 14, 2013 at 4:28:29 PM | Mirroring
jordanjoyful
Thanks, I ended up removing all the sections, replacing, and renaming. All the other notes seemed to be functioning normally.
Mirroring House model
Wed, Oct 27, 2004 at 4:33:14 PM
Mirroring text
Mon, May 12, 2008 at 6:25:23 PM
BE AWARE .... REVIT problems with mirroring
Tue, May 22, 2007 at 12:43:54 PM
More Mirroring
Fri, Mar 23, 2007 at 1:01:51 PM
Opening in Generic Model Standing seam roof
Mon, Aug 17, 2009 at 9:43:32 AM
Page generation time: 1.0274
