Forums >> Revit Systems >> Technical Support >> Color Scheme Dialogue Box not displaying Properly
Fri, Oct 11, 2013 at 9:15:10 AM | Color Scheme Dialogue Box not displaying Properly
Jinxt3r
When the Color Scheme dialogue box is opened on the computer, it display all the columns but none of the data under the columns is visible.
we checked by opening other files, with the same result.
we opened those same files on other computers and the dialogue box displayed properly with all the data in the columns being displayed as well.
We reloaded and over wrote the local file on the machine in question and still the problem persist.  We even rebooted the machine, with no luck.
Is it a display card issue? or perhaps a visual setting in Revit?  Please help.
Fri, Oct 11, 2013 at 9:20:23 AM | Color Scheme Dialogue Box not displaying Properly
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You don't say what year or build you are on.  Make sure you have all of the updates and service packs installed on that machine.  You also may want to try turning off hardware acceleration.  If you go under options is your graphics card an approved card?
Fri, Oct 11, 2013 at 10:07:46 AM | Color Scheme Dialogue Box not displaying Properly
Jinxt3r
running Revit Design suite 2013 on Windows 7 professional.  I tried turning off hardware acceleration, did not change anything.  The card is not approved, but we are running other unapproved cards on other macines without issue.  I have updated the display drivers on the macine in question, did not resolve issue.
Fri, Oct 11, 2013 at 10:09:26 AM | Color Scheme Dialogue Box not displaying Properly
If I remember correctly, you must restart Revit after changing the hardware acceleration setting.
Fri, Oct 11, 2013 at 10:16:11 AM | Color Scheme Dialogue Box not displaying Properly
Jinxt3r
We did. No change.  Going to start the process if installing the service packs.  I currently have all 3 service packs.  Can I just install #3 or do I have to install all of them?
Fri, Oct 11, 2013 at 10:17:41 AM | Color Scheme Dialogue Box not displaying Properly
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You install the service packs in the order they were realeased.
Fri, Oct 11, 2013 at 10:38:51 AM | Color Scheme Dialogue Box not displaying Properly
Jinxt3r
Service packs installed.  Issue still persist.  I would swear it seems like a display setting somewhere, because we noticed all the horizontal and vertical lines in the properties dialog window are missing as well.
Fri, Oct 11, 2013 at 10:43:43 AM | Color Scheme Dialogue Box not displaying Properly
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you restart Revit/your computer after you installed the service packs?  It's not a Revit display issue that I have ever heard of.  You said it works on all of the other computers so do all of your other computers have the same graphics card as this one does?
Fri, Oct 11, 2013 at 10:47:02 AM | Color Scheme Dialogue Box not displaying Properly
It is more than likely the card.  Make sure you have the latest driver for that card.  Is it a different card then your other machines?
Fri, Oct 11, 2013 at 11:00:18 AM | Color Scheme Dialogue Box not displaying Properly
Jinxt3r
It is an older card, but there is another machine with an even older model (it has no display issue).  It's a Nvidia GeForce GTS 450 series and we did install the latest driver.  Definately did a reboot since the updates.
Fri, Oct 11, 2013 at 12:17:02 PM | Color Scheme Dialogue Box not displaying Properly
#11
Jinxt3r
SOLVED
It turns out that when using custom themes in Windows 7 has an effect on the way Revit displays it's information in their own windows.
Revit color scheme issues?
Tue, Sep 16, 2014 at 9:21:21 AM
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Color Scheme Problems
Tue, Jun 26, 2007 at 11:53:16 PM
Page generation time: 0.9764
