Forums >> Revit Systems >> Technical Support >> Creating Wall Extrusions
Thu, Oct 10, 2013 at 3:27:20 PM | Creating Wall Extrusions
gabrielagarcia
Hello,
I am attempting to create some sort of 3D wall feature that extrudes out of the wall but I am only able to create extrusions/mass models on the floor. Is it even possible to create some sort of extruding wall feature on the wall using section or elevation view?
Thank You,
Gaby
Thu, Oct 10, 2013 at 3:37:30 PM | Creating Wall Extrusions
Yes, you can create in elevations or sections - just set the appropriate work plane.
BTW - anything created on the floor can also be moved up ... or even created above the floor based on the extrusion start / stop.
Creating Solid and Void Extrusions
Thu, Jun 1, 2006 at 10:08:08 AM
Extrusions within a project? (2010)
Wed, Jun 17, 2009 at 4:57:54 PM
Creating a steel column with insulation and plaster cover
Thu, Nov 24, 2016 at 11:39:44 AM
creating wall openings with void extrusions?
Wed, Apr 8, 2009 at 4:51:59 AM
Joining extrusions
Tue, Jul 26, 2022 at 3:58:08 PM
Page generation time: 2.2491
