Forums >> Revit Structure >> Technical Support >> Cut profile on a linked file??
Thu, Oct 10, 2013 at 9:25:55 AM | Cut profile on a linked file??
swdebenport
5 Stars: 3 Votes
Is there any way to use the cut profile on a linked rvt file.  We have been using a white filled region for pocketed beam and beams that extend into walls.  I was just hoping for an easier way.
Thu, Oct 10, 2013 at 9:36:38 AM | Cut profile on a linked file??
No....You can not alter linked file elements.
Thu, Oct 10, 2013 at 2:45:27 PM | Cut profile on a linked file??
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Yes, do the cut profile IN the linked file.  Winking  That is what we've done on a Rec Center project with beam cutouts.  The linked model was an existing building.  Make sure you put it on the correct phase.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Thu, Oct 10, 2013 at 3:15:04 PM | Cut profile on a linked file??
swdebenport
5 Stars: 3 Votes
I thought the cut profile tool was a graphics tool not a modeling tool  (since it it under the view tab).  Its a bit much to model, or have the architect model every pocket, for our structure.  Maybe this will be something they can look at in future versions.  We also run into this issue with showing minor braces that we do not model.
Thu, Oct 10, 2013 at 3:33:52 PM | Cut profile on a linked file??
swdebenport - Note rbcameron2 said "IN the linked file...".   Edit cut profile is a 2D solution and only works in the view.  In order for that process to work, you would have to link a view of the linked model ...... and I'm not even sure that will work.
I don't like the idea of doing this.
linked file visability and cut depth [ 1 2 ]
Thu, Jul 13, 2017 at 3:23:18 AM
16
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
Joining Beams and Floors - Beams in a Structural Linked File
Fri, Jun 22, 2018 at 10:07:04 AM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Linked File, how can I dimension it?
Sun, Dec 19, 2010 at 8:08:50 PM
Page generation time: 1.5560
