Forums >> Revit Building >> Technical Support >> Revit 2012 fascia limitations??
Wed, Oct 9, 2013 at 9:11:49 PM | Revit 2012 fascia limitations??
Pele
Pele Avatar
I will try this again! I have attached two images, one is a 3d image of the model, the other image is of an elevation of the building where I have edited the line work to describe the fascia/eave I wish to portray. I had one person offer the thought of creating a fascia to effect the sloped eave which almost worked but they would not miter because the roof does not have any square fascia joins.
I was not able to use the eave tool because it wanted to mak the eaves on a flat plain & all of the eaves on this building slope the same as the roof.
Any thoughts will be greatly appreciated.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Thu, Oct 10, 2013 at 8:09:56 AM | Revit 2012 fascia limitations??
Instead of a facia, why not a sweep?
Thu, Oct 10, 2013 at 5:33:58 PM | Revit 2012 fascia limitations??
Pele
Pele Avatar
Will that cope with the varying eave widths??
Cheers Dermot
www.dmbd.net
Thu, Oct 10, 2013 at 8:57:04 PM | Revit 2012 fascia limitations??
Pele
Pele Avatar
I reproduced the roof as a slab, made a sweep. But when I tried to apply my sweep from my structure tab > floor > slab edge I could only pick one edge of the new slab, but I could pick the floor slab & apply the sweep, not much good! When I pick the new slab the properties tell me its a slab, so why can't I apply the swee to it???
I also made a simple square slab as shown in the attached image where I was able to attach my sweep to 2 edges.
Cheers Dermot
www.dmbd.net
Fri, Oct 11, 2013 at 9:13:35 AM | Revit 2012 fascia limitations??
Floor edge is not the same process as a simple, model in-place sweep.
I'm sorry but your image doesn't mean anything.  You know what you are asking but your not showing us.
Sat, Oct 12, 2013 at 2:06:35 AM | Revit 2012 fascia limitations??
Pele
Pele Avatar
Yes well just trying my best!! in the first post there are two images, one is the 'Revit fascia problem" which shows a square edged roof/fascia the other is titled "Revit fascia required" showing the cut on the underside of the eaves. Hard for me to explain any better??
Cheers Dermot
www.dmbd.net
Sloped Roof Fascia
Wed, May 29, 2013 at 1:23:20 PM
Fascia on Sloped Glazing
Tue, Aug 23, 2005 at 11:58:53 AM
HOW DO I ADD NEW FASCIA?
Tue, Mar 13, 2007 at 3:58:46 PM
More fascia woes.
Sat, Sep 17, 2005 at 1:29:00 AM
Gable End Fascia
Wed, May 23, 2007 at 5:45:50 AM
Page generation time: 2.7972
