Forums >> Community >> Newbies >> Shared Parameter's will not show in Schedules
Wed, Oct 9, 2013 at 8:11:48 AM | Shared Parameter's will not show in Schedules
solarflare
Hi Guys,
I wonder if any of you have some ideas for the following problem, I have created some Shared Parameters and loaded them into my project, they are zone parameters which are categorised under 'Spaces & Rooms' when I created the Shared Parameter as a 'text' input under 'Data'.
When I click on a room 'space' I can see the parameters in the properties section which I then fill in, when I create a schedule of those parameters nothing appears. I have been scratching my head trying to work out why it will not update in the schedule.
Any help would be much appreciated
Cheers guys
124783_Project_Parameters.jpg124783_Schedule_Properties.jpg124783_Properties_of_the_selected_room_area.jpg
Wed, Oct 9, 2013 at 8:36:07 AM | Shared Parameter's will not show in Schedules
Your first screen clearly says these are project parameters - not shared.
Version 2009 - Shared Parameters and Key Schedules
Fri, Jan 30, 2009 at 1:49:25 PM
Shared Parameters in Key Schedules
Thu, Jan 4, 2007 at 1:27:54 PM
schedules show up on sheets too large?
Fri, Apr 21, 2006 at 6:09:20 PM
Shared parameter shows up in Multi Category Schedule But not in Conduit Run type
Mon, Jan 6, 2014 at 2:27:49 PM
Drop down shared parameter
Thu, Apr 2, 2009 at 2:34:29 PM
Page generation time: 1.0298
