Forums >> Revit Building >> Technical Support >> Can't area select a custom family?
Tue, Oct 8, 2013 at 2:09:00 PM | Can't area select a custom family?
buttonsrtoys
1 Stars: 1 Votes
I downloaded from Revitcity a roof-curb family that has a cricket. I did a little customization to it and it's working great. Problem is that I can't area select it. I can click on it to select it, but when I do an area select, it's not included. This is for both an inclusive and non-incluse (right-to-left and left-to-right) select, so I know it's not that something is outside of the boundary. Is there a property or something else that would exclude a family from an area select?
Tue, Oct 8, 2013 at 2:45:01 PM | Can't area select a custom family?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Attach the family . . .
Wed, Oct 9, 2013 at 9:30:30 AM | Can't area select a custom family?
buttonsrtoys
1 Stars: 1 Votes
Sorry - attach the family to the roof? They seem to have attached fine when I view in 2-D and 3-D.
a
Wed, Oct 9, 2013 at 9:45:03 AM | Can't area select a custom family?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Attach the family to this conversation when you reply using the Attachments Button below. See my image attachment.
Edited on: Wed, Oct 9, 2013 at 9:46:00 AM
Wed, Oct 9, 2013 at 2:27:34 PM | Can't area select a custom family?
buttonsrtoys
1 Stars: 1 Votes
I seem to have found the problem. Within View Range my Primary Range defined a space above my roof; i.e., Bottom was set above my roof. My View Depth was below the roof, so apparantly I could see items that I couldn't area select but could pick select? Not why that would be but changing Bottom to be below my roof fix things. I'd be interested in hearing why this is a good feature in Revit if what I think I'm seeing is accurate. (Not trying to be flippant. I'm just wondering if I'm missing something.)
Custum Area Type
Fri, Jan 6, 2006 at 11:57:26 AM
Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
Fri, Nov 22, 2019 at 12:27:55 PM
Parametric Area family or boundery Family
Wed, May 10, 2006 at 7:17:56 AM
Light Fixtures Not Placing/Cutting Custom Ceiling Family
Tue, Apr 14, 2015 at 7:06:55 AM
Material area of part in door family isn't correct
Sat, Oct 15, 2011 at 3:35:55 AM
Page generation time: 1.6170
