Forums >> Revit Building >> Technical Support >> Void in family not visible in Project.
Tue, Oct 8, 2013 at 10:54:47 AM | Void in family not visible in Project.
sippel26
I've added a void sweep to my door as a raised panels.  They show up in fine when I'm in the family.  However, when I load it into a project the voids are not visible.  Please help.
Tue, Oct 8, 2013 at 11:02:25 AM | Void in family not visible in Project.
A void will not show up in the project - only the affects of the void.
Post your family.
Tue, Oct 8, 2013 at 11:04:57 AM | Void in family not visible in Project.
sippel26
Why is that?
Tue, Oct 8, 2013 at 11:12:54 AM | Void in family not visible in Project.
A void is not a 3D element - it changes a solid 3D element's geometry.  The void 'shape' will show up in the family so you will see it there but it that's all.  If your void does not cut the solid in the family then it will not affect the family.
Tue, Oct 8, 2013 at 11:15:00 AM | Void in family not visible in Project.
sippel26
Tue, Oct 8, 2013 at 11:45:22 AM | Void in family not visible in Project.
sippel26
Ok, not really sure what that means but my next question is how do I get the raised panel look that is in the family to also appear in a project when I'm in a 3d view?
Tue, Oct 8, 2013 at 12:05:19 PM | Void in family not visible in Project.
sippel26
Tue, Oct 8, 2013 at 12:10:57 PM | Void in family not visible in Project.
Your family works just fine.
Tue, Oct 8, 2013 at 12:21:44 PM | Void in family not visible in Project.
sippel26
You were able to load it into a project and the voids appeared as planned?  I just tried loading into a new project and still not getting the voids to show up.
Tue, Oct 8, 2013 at 12:52:52 PM | Void in family not visible in Project.
The family seemed to work just fine but I tested it again and found your problem.
You have built some items that are associated with the wrong plane.  If you change your host wall thickness to 6", your door seems to work fine but in a 1'6' wall, it is really bad.
Building wall hosted objects demands you pay attention to hosting.  Test the family in a thick wall to discover what doesn't move correctly, then rework those in the family.
Tue, Oct 8, 2013 at 1:01:05 PM | Void in family not visible in Project.
#11
sippel26
Thank you very much for the help.
Nested Void Problems on Shared Families (doesnt cut nested family if its shared)
Tue, May 10, 2016 at 8:39:49 AM
Family Void cutting through two elements in a project?
Tue, Sep 11, 2012 at 2:55:56 PM
How do I make voids disappear in a family with a yes/no visible parameter?
Fri, Oct 27, 2006 at 1:05:08 PM
void in family is yellow
Mon, Mar 12, 2018 at 12:22:43 PM
nested void family
Wed, Jul 27, 2011 at 2:52:07 PM
Page generation time: 1.6753
