Forums >> Revit Building >> Technical Support >> FLOOR PLAN-VIEW RANGE
Tue, Oct 8, 2013 at 4:03:54 AM | FLOOR PLAN-VIEW RANGE
LOSpistos
Hi to all,
Im having interesting issue which i dont know how to solve. Im having multistorey building in my model and each floor plan should display whats happening on the ground floor below (landscape, trees / site with roads). I dont know how to set up the view properties to see just the landscape without showing the internal walls below each floor.
Luba
Tue, Oct 8, 2013 at 4:43:35 AM | FLOOR PLAN-VIEW RANGE
ronmalit
5 Stars: 3 Votes
hi. hope you are open for suggestion. ill go for opt 2 then opt 3 then opt 1..
opt.1: you can play around the plan region:
set the floor plans view range to be same as the level 1 or site to show the landscapes. then create plan region and set the plan region for each level to the desired view range to cut the building internal.
opt2: as link file
save the landscape (trees site road) as another file. then link it back to the project. in each floor plan/level you can VG and custom the link file (link view) to show level1 or site in every floor
opt3: as detail item
freeze the landscape or export it to autocad (trees site road). clean it and the load to a generic detail item family. then load the family in every floor plan level
Edited on: Tue, Oct 8, 2013 at 4:45:03 AM
Edited on: Tue, Oct 8, 2013 at 4:45:28 AM
** dont be mad, i dont have much... i am homeless
Tue, Oct 8, 2013 at 9:00:35 AM | FLOOR PLAN-VIEW RANGE
The plan region will work but so will a floor.  That seems to be the easiest....
I would never use the autocad solution (NOT) ronmalit proposed.
Wed, Sep 13, 2017 at 1:42:00 AM | FLOOR PLAN-VIEW RANGE
zakazai
Hi LOSpistos
Did u find the solution for it?
Plan Region and View Range issue
Tue, Sep 26, 2017 at 7:27:30 AM
plan region/view range window
Mon, Feb 9, 2009 at 4:39:34 PM
view range on uderlay inconsistant with view range of plan view
Thu, Sep 4, 2008 at 3:48:11 PM
Associated Level in View Range
Wed, Nov 12, 2008 at 8:36:23 AM
View range problems with framing plans
Tue, Feb 23, 2010 at 1:48:16 PM
Page generation time: 0.9096
