Forums >> General Discussion >> Revit Project Management >> Linking Revit Models
Mon, Oct 7, 2013 at 11:41:44 AM | Linking Revit Models
EBrandon123
We have just received the Revit survey for our building which I want to overlay on my model. The problem is when I link the survey model to my model it disappears and I can only see it through a 3d view.  I have tried to locate it through an elevation view by moving the elevation extends and crop regions out but I still cannot see it. What is the best way to link/Overlay Revit models?
Mon, Oct 7, 2013 at 12:24:04 PM | Linking Revit Models
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
See this link for information on Shared Coordinates.
http://paulaubin.com/_downloads/2011_AU/Papers/AB3733_Aubin_SharedCoord.pdf
Mon, Oct 7, 2013 at 12:35:27 PM | Linking Revit Models
Do you mean the site is off to the side?  ... or below your model elements?....
You say Revit survye but do you mean a CAD dwg or really a Revit Model?
Tue, Oct 8, 2013 at 3:44:14 AM | Linking Revit Models
EBrandon123
We are renovating a building which I originally drew by inserting dwg survey drawings into my revit project.
We have now recieved a revit survey of the building which is more accurate. ( I have now managed to overlay the survey model over mine)
Is it better to:
1. Delete my existing information, then copy / paste the existing information from the survey model into my model or
2. Delete my existing information and have the survey model referenced into my file.
I will need to remove existing openings and add new openings into the existing walls.
Tue, Oct 8, 2013 at 7:16:58 AM | Linking Revit Models
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Link in the topo into your project using the information in the link I gave you.
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
Linking Other Models
Tue, Aug 31, 2010 at 1:35:54 PM
Linking the Autodesk Advanced Models Together
Mon, May 19, 2014 at 2:02:04 PM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
linking models into models
Fri, Aug 24, 2007 at 12:55:28 PM
Page generation time: 2.8373
