Forums >> Community >> Newbies >> Window cut plane
Fri, Oct 4, 2013 at 4:08:24 AM | Window cut plane
neotropic
Hey guys,
I know this is a ridiculously simple thing but I am not able to figure it out right now.
The window should appear white on the plan view
The thing is that I created some extra levels. On some levels the window appears white while on these levels, that I created, they appear grey
Can somebody help me with this?
Fri, Oct 4, 2013 at 7:51:24 AM | Window cut plane
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Not enough information to really help you.  Are you using phases? What is the window elevation from floor level?  What are your levels and their view ranges?
Fri, Oct 4, 2013 at 8:15:25 AM | Window cut plane
This is user error most likely. Check your view cut plane settings.
window does not get cut in plan view.
Tue, Jul 12, 2011 at 10:37:20 AM
window above cut plane is visible. why?
Fri, Nov 27, 2009 at 9:25:10 AM
Showing High Windows Cut In Plan
Mon, May 28, 2007 at 3:09:47 PM
Window not visible, only opening - Revit 2008
Tue, Jan 22, 2008 at 10:30:53 PM
CUT PLANE IN wINDOW
Tue, Jan 12, 2010 at 4:43:51 PM
Page generation time: 1.8910
