Forums >> Revit Building >> Technical Support >> Placing Reveals around openings- Windows & Doors
Thu, Oct 3, 2013 at 12:46:31 PM | Placing Reveals around openings- Windows & Doors
kalpanaips
Hi
  Thsi must be so simple an issue, but I have spent more than a few hours trying to figure it out. So I thout I will put it out here and get any help I can.
  I want to create reveals around windows and doors in this project. I created a profile sweep (reveal) and selected the path around the opening. So far so good. But when I change the properties of teh sweep from solid to void- I get an error message. "Some Void Forms of this family do not cut anything and will be deleted. To make a Void Form cut something else use the Cut Geometry tool." I need to be able to place this reveal around many different opening in the project.
I haev attached the model here. The solid sweep that is around the window needs to be a void instead. I have tried it a 100 times on different wall profiles, with no luck. I really appreciate if anyone can help me solve this puzzle.
Thanks much.
Edited on: Thu, Oct 3, 2013 at 1:13:43 PM
Thu, Oct 3, 2013 at 12:51:53 PM | Placing Reveals around openings- Windows & Doors
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to cut the wall with the void.  If you are placing this in a lot of areas in the project you are better off actually making it a part of the window family. I am trying to picture why you would want a reveal around the windows and door?  there is no model attached. It is most likely to big.
Thu, Oct 3, 2013 at 1:15:12 PM | Placing Reveals around openings- Windows & Doors
kalpanaips
Teafoe
    I did attach an image now..
    Thats what I thought... tried to use "Cut Geometry" but it was not letting me do that either!
Door & Window Schedules - how to schedule existing doors and windows
Tue, Feb 3, 2009 at 11:11:39 AM
Creating Family/Placing doors and windows
Mon, Apr 9, 2018 at 10:09:40 AM
creating openings and putting doors and windows in fluid structures
Tue, May 7, 2013 at 9:22:07 AM
Placing doors/windows at midpoints of walls??
Tue, Jan 25, 2005 at 5:44:52 PM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:28 PM
Page generation time: 0.9906
