11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> How to overlap wall types in a vertical plane in a stacked wall.
Has any one done this or found a work around. I could just simply draw another wall, just 300mm along the stacked wall at the desired height, but then it will not be cut where my doors are. Please find explanation attached.
Stacked walls are great for initial placement but I prefer to break them up afterwards so that the individual components can be modified. Doing that would allow that external skin to be pulled down.
Remember - a stacked wall is really just like a group. It is NOT a true wall type. It can NOT be tagged - only the components of the stack can be tagged.
Thansk for your advice, i kind of didn't want to break it up as sometimes we move the whole wall and decide to change heights etc etc. Though I guess ill break up and bring the cladding down 300mm Cheers
Staggered Stacked Wall Join Problems |
Tue, Oct 14, 2008 at 12:50:52 PM
How do you hide the joint lines between different wall types? |
Fri, Nov 16, 2007 at 8:16:34 AM
stacked wall line visable on the wrong side? |
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
Misbehaving (stacked) wall |
Mon, Apr 17, 2017 at 1:10:32 PM
