11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Could not create integral wall sweep for wall instance......
What does this mean when one creates a wall with siding in accordance with http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Modeling/Creating_Log_Walls_in_Revit
Could not create integral wall sweep for wall instance. Sweep position is outside of its wall. Please check sweep parameters.
You have a sweep that is attached to the wall profile but is not inside the wall. You may for instance have a sweep at 10' but your wall is only 8' tall
NOTE: With this process, even in 2014, the sweeps still will not cut at an angle when joined to a roof. (Upper left sweep in image) An in-place void will cut the sweep as can be seen below.
True log homes have staggered logs side to side.
ERROR: could not create integral reveal from wall instance. fail to cut wall. |
Mon, Jan 8, 2018 at 8:30:21 AM
Integral Wall Sweeps |
Wed, Mar 12, 2008 at 3:44:55 PM
Base Extension Distance + Wall Sweep (at base) |
Wed, Jun 3, 2015 at 6:26:49 PM
Wall Sweep profile family problem |
Tue, Oct 2, 2012 at 6:41:22 PM
Wall Sweeps above Top of Wall - Revit Arch 2013 |
Tue, Dec 10, 2013 at 12:10:48 PM
