14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Blank values in parameters
Hi,
I'm adding a number value parameter (for heat loss) which applies to some of my windows.
Once I've set up the parameter the initial values are blank - I can then add what I need to the appropriate windows - this all displays perfectly in the schedule.
But, if I accidentally add I can't and want to remove it, I cannot set the parameter back to a blank value - I get 'Enter a value or formular starting with =' error.
How can I set the value back to blank as it originally was?
If the schedule is suppose to read a value you will need to enter a number. If you want it to read blank again you most likely would have to reinsert your window.
yea - thats what I did in the end - bit it took ages to do it as it affected many windows.
there has got to be an easier way...
Did you try it using a text parameter instead? I believe those can be left blank.
We probably need to put this issue on the official wishlist because many of us have seen this problem.
Do you know the address of the official wish list - I've added to a few wish lists, but I've not seen an official one.
As far as I know - autodesk seems to pay attention to AUGI.
room tag blank field |
Tue, Sep 25, 2007 at 8:33:16 PM
using schedule keys, shared parameters and calculated values in schematic design |
Tue, Mar 6, 2007 at 1:41:36 PM
Instance Parameters Resetting |
Mon, Jan 28, 2019 at 1:20:31 PM
Room parameters |
Sun, Mar 30, 2014 at 1:22:55 PM
Material Library with custom parameters. |
Fri, May 6, 2016 at 3:36:29 PM
