Forums >> Revit Building >> Technical Support >> Revit Viewer Mode
Tue, Oct 1, 2013 at 10:16:37 AM | Revit Viewer Mode
jjl2036
Hi, I installed revit 2014 full licenced student version yesterday and started working on a model, saved, and shut down. Today I went to reopen and work on it (have been working on it for the past 4-5 hours) and realised it hadn't prompted me to save all night. Went to manually save and realised that I had opened the file in Revit Viewer Mode Sad it is telling me I can't save and I was wondering if there is any way around this as I don't want to loose all my work.. Rookie error, but hoping someone will be able to help! Thank you in advance!
Tue, Oct 1, 2013 at 10:19:14 AM | Revit Viewer Mode
Looks like you will pay for your mistake.  You need a properly licensed version to save anything.
Tue, Oct 1, 2013 at 10:25:21 AM | Revit Viewer Mode
jjl2036
Hi WWHub, thanks for your response. Would you be able to clarify what you mean by 'properly licenenced version'? As I have downloaded it from the Autodesk website directly and have the serial and product number they sent me, hence why I was able to save last night. I think what happened is that when I went to reopen the file today, I accidentally opened it in the Revit Viewer Mode instead of just Revit...
Tue, Oct 1, 2013 at 11:03:09 AM | Revit Viewer Mode
You have to open it with your student license.
viewer for Revit 2014?
Wed, Apr 23, 2014 at 3:13:04 PM
Revit Viewer
Fri, Mar 19, 2010 at 9:15:30 AM
Revit File Viewer
Wed, Mar 19, 2008 at 6:28:11 AM
Create Your Own BIM Tool in Minutes with bimU.io Viewer API
Thu, Sep 24, 2020 at 5:51:51 PM
Can I render in Family mode?
Mon, Mar 29, 2010 at 6:37:04 AM
Page generation time: 4.6663
