Forums >> Revit Building >> Technical Support >> Glider Window in pocket
Tue, Oct 1, 2013 at 9:34:14 AM | Glider Window in pocket
SVM1Steve
I am trying to create a parametric glider window that will pocket into an exterior wall. I have ran into a stumbeling block and cannot get it to finction properly when loaded into a project. Could someone please take a look at it and let me know what i need to do to fix it. Our office is currently running Building Design Suite 2014. Thanks in advance for the help.
Tue, Oct 1, 2013 at 9:58:07 AM | Glider Window in pocket
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Please tell us what is not working properly so that we don't have to dig through and try to find out ourselves.
Tue, Oct 1, 2013 at 10:15:52 AM | Glider Window in pocket
As teafoe says - you should really ask a complete question.  This is a business that requires communication.
If your problem is the pocket.  You can only ha a wall cut but you need a void for the window and a void for the pocket.  You can delete the wall cut and then you can add voids as needed.  Read more on this in similar threads.  Also I suggest you download the families guide from the autodesk site.
Tue, Oct 1, 2013 at 11:43:31 AM | Glider Window in pocket
SVM1Steve
when i drop it into the plan, there is no void in the wall so that it shows up correctly. In the model attached I do have a void drawn but it is not cutting the wall. so basically the wall (pocket) still shows solid. @ WWHub, you talk about only having a wall cut and not a void. When i created the window i did use the "void extrusion" to make it. Could you please verify what/how you are refering?
Tue, Oct 1, 2013 at 1:17:52 PM | Glider Window in pocket
You need to read my post again.  You can not have a wall cut and a void!  Delete the wall cut, then replace that with a void and add another void for the pocket cut.
Better yet, download a pocket door from the downloads and examine how that family is built.
Tue, Oct 1, 2013 at 1:44:55 PM | Glider Window in pocket
The "families guide" will show you how to do this.
Just recognize that Revit likes things done in order and you are doing yours backwards.  Adding a void afterwards will cut your geometry instead of the wall.  Make the void away from your elements then move it into place.
Tue, Oct 1, 2013 at 1:52:22 PM | Glider Window in pocket
SVM1Steve
i did try the pocket door and went through the parameters and tried to set mine up as it appeared in the pocket door and the attached is what i ended up with. thank you, i shall check out those help files.
Tue, Oct 1, 2013 at 2:01:56 PM | Glider Window in pocket
nothing attached
Wed, Oct 2, 2013 at 7:03:59 AM | Glider Window in pocket
SVM1Steve
I was refering to the first post!
Pocket window
Sun, Oct 16, 2005 at 6:11:31 PM
Problem creating a pocket
Thu, Feb 7, 2008 at 2:14:32 PM
Pocket doors?
Sat, Jan 5, 2008 at 5:19:04 PM
I am looking for a pocket, double side window. Where can I find it? thanks
Wed, Jul 20, 2005 at 8:05:01 AM
Pocket doors
Fri, Jan 26, 2007 at 1:39:39 PM
Page generation time: 1.3060
