Forums >> Revit Building >> Technical Support >> Components not showing up in Plan
Mon, Sep 30, 2013 at 12:29:36 PM | Components not showing up in Plan
MattGroverCo
5 Stars: 2 Votes
Hello,
We are using Revit Arch 2014. In my floor plans some of the 3-d componets ie: beds, vanitys, ref etc... are not visable in floor plans. They are turned on in properties. They are not hidden. The cut plan is adjusted correctly. When we turn on the light bulb they are visable. When the light bulb is turned off they go away. When you mouse over the object you can select it. You just cant see it. Very weird and have tried everything we can think of. I havent found another post on here about this issue. Going to call Pacific Cadd soon.
Thanks for any ideas or help.
Mon, Sep 30, 2013 at 12:51:45 PM | Components not showing up in Plan
Are they really 3D in plan or just 2D in plan views?  Typically the problem is the element is under your floor surface.  Turn off the floor and see if they appear.
Tue, Oct 1, 2013 at 2:41:20 PM | Components not showing up in Plan
MattGroverCo
5 Stars: 2 Votes
Thanks for the responce. I turned off the floor and it did not show up. I made sure it was set to the elevation i needed. Do you think it may be the componet. A guy in my office had the same issue with a vanity componet. He used a different one and it showed up. The componets show up in section btw.
Tue, Oct 1, 2013 at 2:50:39 PM | Components not showing up in Plan
For sure it could be the component.  Open the family - make sure it is in the category you think it is.  See if there are any model elements set to be seen in plan views.  If not, are there any annotative elements in the family plan view?
Roof Plan not Showing in Site Plan
Wed, Jul 12, 2017 at 12:03:32 PM
11
Cars not showing in renderings but showing in site plan, help hurry please
Fri, May 6, 2011 at 6:01:49 PM
VIEWING LEGEND COMPONENTS PROPERLY
Tue, Apr 14, 2009 at 10:04:02 AM
Furniture as detail components
Wed, Nov 9, 2011 at 5:30:43 PM
Mullions not showing in plan
Mon, Apr 12, 2010 at 7:19:22 AM
Page generation time: 0.6889
