Forums >> Revit Building >> Technical Support >> make an irregular window
Mon, Sep 30, 2013 at 12:27:27 PM | make an irregular window
ArqGracielaC
how can i make a window that is not a rectangle?
i made a family but the wall opens a rectangle hole, i need a hole that folow the shape of my window
Mon, Sep 30, 2013 at 12:49:56 PM | make an irregular window
You need to remove the wall cut from the family and add a wall based void that cuts it instead.  PLEASE LISTEN,,,,  You will have problems if you don't.  Make the void somewhere outside of your element in any shape then set it to cut the wall.  After successfully do that, then edit the void to the shape and location you want.
If you initially place the void where you want it, the void will cut all of your components as well as your wall.
Mon, Sep 30, 2013 at 1:09:19 PM | make an irregular window
ArqGracielaC
soory i really new usining revit, could you tell me step by step?
Mon, Sep 30, 2013 at 1:14:47 PM | make an irregular window
Download the families guide and read it....
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
Mon, Sep 30, 2013 at 1:38:43 PM | make an irregular window
ArqGracielaC
thank you!
how to make an irregular slope surface
Fri, Apr 1, 2011 at 10:12:27 PM
Irregular Ceiling
Mon, Aug 4, 2008 at 1:45:52 AM
Curving a Truss around an irregular mass
Sun, Mar 1, 2009 at 8:19:44 AM
Triangular bay windows
Wed, Feb 16, 2005 at 8:01:13 AM
irregular patterned stucco wall
Tue, Jan 27, 2009 at 9:03:41 AM
Page generation time: 2.5473
