Forums >> Revit Building >> Technical Support >> Multiple sheets with the same name.
Mon, Sep 30, 2013 at 7:39:08 AM | Multiple sheets with the same name.
stefanlarsson
Hey!
Im not sure I made this thread at the correct place, if not feel free to correct me...
We are currently working on a project in revit 13. It's my offices first project that is made 100% in revit and we are having some truble solving an issue with the fact that multiple sheets cannot have the same number/name. We would like to have the same sheet number on sheets used in different phases of the project. Like for instance we want the floor plan for the first floor to be named ”A-40-P-010” but we want different versions of the sheet to be used during different phases of the project.
I'm not sure my question makes sense since I don't really know how to translate the work process, but simply put: How do I create several sheets with the same name?
Is the way to go on about this to make a new project and link the model in to the new project and make sheets from there? Or is there better ways?
/Stefan
Mon, Sep 30, 2013 at 8:10:26 AM | Multiple sheets with the same name.
As you have found out, you can't have sheets with the same number, the same name is no problem.
I personally don't understand why you would want the confusion of having two sheets with the same number/name but that is your problem to deal with.  I would simply add an additional letter in the sheet number.
Your seperate project with the linked model would be a solution for you.
Mon, Sep 30, 2013 at 8:20:06 AM | Multiple sheets with the same name.
BTW - I just wanted to add that any confusion your sheet numbering would create would be a real liability in a court case.
Mon, Sep 30, 2013 at 9:16:35 AM | Multiple sheets with the same name.
stefanlarsson
Thank you for the reply. I guess I could probably be sounding a bit confusing since I don't really know the different standards in different countries. I am even quite new to swedish standards. (I've been working in the production side of construction for some time and recently changed my line of work to the architectural side, so I am  a little outside my comfort zone overall. furtunately I have experienced coworkers but they are all inexperienced to revit.)
The Idea is that we produce 3 sets of sheets.  One to apply for a building permit, one for the construction and one final set that shows how the building turned out in the end. Some of the sheets will be a part of all the sets. When working in the middle phase we would like to keep the sheets for the building permit as they were when we applied since we generally need to do revisions to them while working on the sheets for  construction.
We also want to have consistent sheet numbering for all three sets without having to use "bad" sheet numbers for 2 of the sets because we used all the "good ones" for the buiding permit. I realize that we probably are thinking about this the wrong way, after all we are revit noobs =)
Maybe what were looking for could actually be done with good use of filters or phases.
Mon, Sep 30, 2013 at 9:24:59 AM | Multiple sheets with the same name.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Maybe I am not still really understanding but it sounds to me like you would just do this with sheet issued dates/revisions.  You can also check a box in the sheet properties for what sheets you want to show up in a sheet index so if you want sheet A101 to show in the building permit issued set you would check it and if you send out for construction and do not want it you just uncheck the box. You are not going to be able to keep everything the same from the first issue to the next while still working on the "next issue", if you want to do that you will need to have multiple files (which I don't think is good or understand why you would do this). We make a PDF set of every issue that we submit so that we can see what we submitted and what changed in the newer submittals.
Mon, Sep 30, 2013 at 9:30:46 AM | Multiple sheets with the same name.
We keep PDF records of out sheets at each submission - that is adequate here.
We did a multi-bid/phased project where foundations and structure were bid early.  As a consequence, the model elements for those portions of the work changed as the build-out set progressed and had to be addressed as addendums to the work in those early bid phases.  In that project, we added a bid-package letter to the sheet numbers.
All of the sheets were in the same project and were organized according to BP in the browser.  Whenever we made a change in the model that affected an earlier release, we were able to cloud it immediately in the earlier sets.  We then issued addendums  as required.  When the project was finished, all changes had been recorded in all Bid Packages.
Mon, Sep 30, 2013 at 10:11:31 AM | Multiple sheets with the same name.
stefanlarsson
thanks for all the input!
What you did with the BP project is excactly what we are doin with this project atm but since this is not really a big project (about 60 appartements or so) it feels like we are not doing things in the most efficient way.
I think most of our problems could be solved with a little smarter useage of view templates and filters.  I will have to do some more investigation , then I'll probbably come back with some even more vague questions about this =)
Tue, Oct 1, 2013 at 8:38:43 AM | Multiple sheets with the same name.
archigrafix
5 Stars: 4 Votes
Here in Norway we usually use the same drawing number, revision numbers, and archive drawings submissions in PDF. This is a very practical / consistent way of producing documentation for the moment - inherited from old CAD habits. It often happens that drawings for planning application (1:100) have a different scale than construction drawings (<1:50), therefore they will be different drawing / different numbers.
Another thing. Unless one uses Revit phases, it's very hard to compare the different stages of the project, in terms of areas / quantities, etc. That might be useful to document changes - I think it's good to plan phases also depending on documentation.If one does not use phases the model just keep changing...
I expect that Revit in the future may have a more elegant way of archiving project revisions and allow accessing previous drawing/project revisions, not to depend on the very limited information present on the PDF files.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Fri, Oct 18, 2013 at 7:19:00 AM | Multiple sheets with the same name.
stefanlarsson
Bringing an old thread to life again...
I would guess that Sweden and Norway has quite similar standards. We do keep records of all sheets published in PDF format and that part is really not a problem. The problem right now is that the planning documentation used to apply for a building permit, the construction documentation and the documentation of the finalized project all use the same sheet numbers (as a standard) and also uses the same revision numbers.
The Documentation of the finalized product is only done once, when the constuction comes to an end, so it is not a big problem since we at that point does not need to go back and work with the construction plans. But it would be convenient if it could be done in a more elegant way.
As Archigraphix pointed out, lots of the construction plans has a scale of 1:50 while application plans generally have a scale of 1:100, automatically giving us different sheet numbers anyway (which is totally fine). Howeer this is not true when it comes to elevations nor site plans. Also some contractors wants plans in 1:100 for a better overview.
Now all this I managed to controll pretty smoothly with the use of wiew templates and some parameters to change how information is presented in the titleblock depending on what phase the sheet sheet is set to. (Application, Construction or Finalization). However there is one big problem: Revisions.
I have no idea how to handle this. We use the same revision numbers for all hases. Alphabetically starting with A... So, all phases have different revission histories and the all need to be alphabetical starting with A. From what I understand Revit can not have multiple "sets" of revisions?
is there a way around this? Im thinking something like using schedules in some smart way to list the revisions you want and manually add numbers...
Anyone have some ideas to share about this?
View alignment on Multiple Sheets
Thu, Aug 27, 2009 at 2:12:19 PM
Engineering Stamps on Multiple Sheets
Wed, Apr 8, 2015 at 11:13:44 AM
Spread a schedule over multiple sheets - Issues
Mon, Aug 29, 2022 at 6:32:10 AM
Same View on Multiple Sheets
Sun, Aug 28, 2005 at 5:51:36 PM
Change multiple sheets' properties at once [ 1 2 ]
Sat, Nov 1, 2014 at 8:50:25 AM
16
Page generation time: 0.8082
