Forums >> Revit Building >> Technical Support >> mullion ang transom not fitting well
Thu, Sep 26, 2013 at 6:39:59 AM | mullion ang transom not fitting well
jun1304
I have to model curtainwall that is double curve in plan and curved in vertical section, as the floor goes up the width is getting bigger, looks like trapezoid in elevation. I used massing but then the connection between mullion to mullion and mullion to transom was very ugly.  I try also using adaptive type but the glass goes in and out when I placed them in the project, and the mullion to mullion connection is bad also.  Can someone help me on this? Many Thanks,
Thu, Oct 3, 2013 at 10:00:23 PM | mullion ang transom not fitting well
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Here is the way i use in simular cases.
used pattern based template.
http://youtu.be/RfFmkBWrf_Q
want more?
You can get more tips at Enjoy Revit
Sun, Oct 6, 2013 at 2:57:58 AM | mullion ang transom not fitting well
jun1304
Thanks Dingohot for your reply,This will work if your mullion and transom are the same shape, but in my case, my mullion is triangle and my transom is square, any suggestion? hoping for your help. many thanks...
Sun, Oct 6, 2013 at 3:29:09 AM | jun1304
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting jun1304 from 2013-10-06 02:57:58
I suppose I can help you if you upload a shape sketch or something you want to make.
want more?
Sun, Oct 6, 2013 at 6:15:09 AM | mullion and transom not fitting well
jun1304
hI Dingohot,
Here I attached my two failed attempt, PLease kindly look at it... thanks a lot.
Sun, Oct 6, 2013 at 6:35:35 AM | mullion ang transom not fitting well
jun1304
Can you also please kindly check what is wrong with this adaptive component i make? because when I try to plot in my massing sometimes the profile was flipped back or sometimes the glass goes the outside..  Thank you very much. I need help very badly..
Sun, Oct 6, 2013 at 8:17:17 PM | mullion ang transom not fitting well
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Now i have a question.
1. why that detailed model necessary? what for? make model simple and use drafting view for detail documents.
2. it doesn't seem double curved face. I dont think adaptvive or pattern based families necessary for single curved face.
3. have you tried with mullion joiin type? see attached image.
want more?
Mon, Oct 7, 2013 at 12:21:54 AM | mullion ang transom not fitting well
jun1304
Hi dingohot,
1) my system is unitized so it needs to be modelled per module, same the way it was deliver and installed in site. Each trapezoid shape on conceptual mass attached are my panel shape.
2) Here I attached the actual part of building conceptual massing. it was double curve in plan and also curved on vertical section. none of the adjacent panels are the same and the shape of each panel is trapeziod.
3) Mullion joint not applicable.
Many thanks Dingohot, still looking for your help...
Mon, Oct 7, 2013 at 1:09:46 AM | mullion ang transom not fitting well
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
ok. i think i can try if i had profiles of mullion & transom you want to use.
can u upload profiles? in dwg or revit file.
want more?
Mon, Oct 7, 2013 at 1:42:39 AM | mullion ang transom not fitting well
jun1304
Hi Dingohot,
Thanks for prompt reply,  here I attached the mullion and transom used.
thanks again...
Mon, Oct 7, 2013 at 1:42:48 AM | mullion ang transom not fitting well
#11
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
check attached file. I'm not sure but i think this should be what you want.
hope you can find a clue from attached file.
Enjoy. :-)
want more?
Mon, Oct 7, 2013 at 2:13:44 AM | mullion and transom not fitting well
#12
jun1304
Hi Dingohot,
As I looked in your sample, it was not as per module as i want it to be?
Can you please kindly apply this panel in my attached mass previously?
thanks again
Mon, Oct 7, 2013 at 2:24:41 AM | mullion ang transom not fitting well
#13
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
i just saw your profiles... I think my last reply will score, Or seprate profiles left/right, top/bottom and make a border with them at pattern family.
but for fig4 from your pdf (gap between border mullion),you have to anoter custom pattern or adaptive family to make it fit.
i don't think it's impossible, but there is no easy way i guess.
anyway... what on earth this kind of model necessary?????? i really don't get it though you explained...
want more?
Mon, Oct 7, 2013 at 2:44:35 AM | mullion ang transom not fitting well
#14
jun1304
Hi,
Please correct me if im wrong,  In the specs we have to deliver up to LOD 500, and there is a chance that this will run in 4d time simulation, the panel should be modelled as per module, same as we are going to install them on site. and for the connection of profile, the consultant will surely notice these connection, as per my understanding we should model the curtainwall as almost same replica of what we will deliver and install in site.  Need your advise.. thanks in advance
Mon, Oct 7, 2013 at 4:47:09 AM | mullion ang transom not fitting well
#15
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
oh, so you're not making the model to make documents.
I'm an architect in Korea, so i have not much idea what is going on other contryies with Revit or BIM.
But i'm quite sure that mullion is just mullion. i mean any mullions are made in fatoryies, not in site. so, it doesn't matter that shape of mullions in model, just identfication in model does. on site, they just delivered and assembled.
Also about 4d simulation. whats big difference between triangle and rectagle mullions in 4d simulation?
I could be wrong. this is just my opinion.
want more?
Mullion
Sat, Oct 17, 2015 at 9:53:54 PM
Change which fitting family is automatically applied while connecting duct?
Wed, Jul 22, 2020 at 11:20:15 AM
Sanitary fitting isnt working right
Wed, Aug 21, 2019 at 11:19:32 PM
Curtain wall panel not extending up to mullion...
Wed, Aug 7, 2013 at 8:28:59 AM
spider fitting for point supported glass
Wed, May 10, 2006 at 12:51:08 PM
Page generation time: 0.7781
