Forums >> Revit Building >> Technical Support >> Wall Build-up displaying incorrectly
Wed, Sep 25, 2013 at 7:17:11 AM | Wall Build-up displaying incorrectly
SimonBea
I have just noticed two instances in our model where wall build-ups have gone a stray.
In the attached image WG16 is a window placed in the external wall. This wall is one continuous wall running across the image. The wall build-up to the right of the window is displaying correctly. However to the left you can see that for some reason the inner leaf has changed to display as a concrete type hatch.
Second attachment shows intended wall construction
I really can't work this one out, it is all the same wall so don't see how this can be controlled. If I delete the window the whole wall changes to the incorrect build-up. If I throw a section through the wall it shows correctly.
There is another instance of this similar thing happening in the model but vertically as well.
Any ideas?
Thanks
Edited on: Wed, Sep 25, 2013 at 7:18:30 AM
Wed, Sep 25, 2013 at 8:39:49 AM | Wall Build-up displaying incorrectly
Hide the wall on the left and see what's left.  I don't believe this is your wall.
3D view with photograph background displaying incorrectly
Fri, Sep 19, 2008 at 2:52:55 AM
Wall and Instance phasing warning - Incorrectly Reporting?
Thu, Oct 11, 2018 at 3:37:00 PM
Plumbing fixtures not displaying
Mon, Feb 6, 2006 at 1:12:33 AM
Properties window and Project Browser displaying incorrectly
Fri, Aug 7, 2015 at 8:35:37 AM
2015 CURVED WALLS NOT DISPLAYING IN REVIT CORRECTLY
Fri, May 6, 2016 at 9:21:20 AM
Page generation time: 1.8732
