Forums >> General Discussion >> Revit Project Management >> Callout Details
Wed, Sep 25, 2013 at 4:57:14 AM | Callout Details
EBrandon123
I am detailing up parts of my model by using callouts from my 1:100 Section. The details need to be 1:5, so the problem is when I adjust the clip plane in the 1:5 callout detail this then reduces the callout bubble on my section to a tiny bubble.
Is there a way the callout clip in the 1:100 section can stay larger so it reads better?
Wed, Sep 25, 2013 at 8:16:25 AM | Callout Details
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The callout region in the 1:100 is the callout for the 1:5 so obviously if you change one the other will change also, this is what Revit does.  When we go from building sections to wall sections to details so that we aren't jumping from a 1/16" section to a 1 1/2" section.
Wed, Sep 25, 2013 at 8:34:38 AM | Callout Details
???? I don't understand what you are doing.  The callout is in your 1:100 view and the bubble size is what it is.  The actual view is 1:5 and it does not have the bubble.  These are two different views.
Wed, Sep 25, 2013 at 9:05:23 AM | Callout Details
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
WWhub I believe he is using the wrong terms.  He is referring to the actual region of the callout not the head itself.
Wed, Sep 25, 2013 at 9:38:05 AM | Callout Details
TEAFOE ... I understood but it sounded like he was saying the bubble changed size.   I re-read it and I now see what the problem is.  He needs a 'fake' callout that is larger than his actual view.  In another post I recommended:
  1. make a normal callout and hide it - this is your sheeted view and adjust the crop region as you need
  2. draw your new call lines as you want...just linework
  3. add a new detail callout referencing your first call out (note - this may create a SIM if you have it setup that way.)
  4. instead of bubbling the area, just make a very-very small bubble along your fake call-out line.
NOTE :  Remember - this is a fake callout so pay attention when things change.
Wed, Sep 25, 2013 at 9:45:31 AM | Callout Details
EBrandon123
Thank you both for your answers, I believe I was using the wrong terms but now you both understand what I was asking. By the way I am a she not a he
Wed, Sep 25, 2013 at 10:31:24 AM | Callout Details
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Sorry about the confusion I get in a habit of saying "he".  Eitherway glad we could help.
DETAILS IN SECTION CALLOUT
Mon, Apr 21, 2008 at 12:45:37 PM
Callout outs
Wed, Oct 5, 2011 at 3:57:44 PM
callout only head
Tue, Mar 26, 2013 at 7:09:20 AM
Callouts/Details
Fri, Jan 25, 2008 at 4:01:11 PM
can Callout duplicate detailed drawn on section view?
Thu, Oct 4, 2012 at 11:05:02 AM
Page generation time: 0.3475
