Forums >> Revit Building >> Technical Support >> Pier in brick
Mon, Sep 23, 2013 at 2:42:50 PM | Pier in brick
rjf1212
I am new to revit i am using 2013 i would like to know how i add materials to a column so it has the look of a brick pier/pillar in my project i have attatched materials but its not showing in any of my views hatched with brickwork can someone please help me thanks
Mon, Sep 23, 2013 at 2:59:37 PM | Pier in brick
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Not enough information on your problem.  Do you have a hatch pattern assigned to your material?  Are you sure you have assigned a material to the column?
Mon, Sep 23, 2013 at 3:04:43 PM | Pier in brick
Architectural columns will assume the material of a wall it is placed against.  Structural columns will not.  What do you have?
Tue, Sep 24, 2013 at 12:22:27 PM | WWHub
rjf1212
I have drawn a extension which is in brick but the colomns are not attatched to the brick wall they are independant which carry a cateleiver roof i have had alot of experience with architectural dektop but im very new to revit im not sure if i have assigned the material or the hatch correctly thats what i would lke to know how to do if you have the time would be ver gratefull thanks
Quoting WWHub from 2013-09-23 15:04:43
Tue, Sep 24, 2013 at 12:31:04 PM | Pier in brick
This is an architectural column and the materials are set in the type.
Tue, Sep 24, 2013 at 12:58:28 PM | WWHub
rjf1212
thanks for your help fixed it now i can get my plans finished this revit is so much better than adt it has some amazing capabillities thanks for your time everyone
Pier Shading
Tue, Mar 19, 2019 at 1:42:11 PM
openings in walls
Tue, Feb 3, 2009 at 11:06:47 AM
Straight shaft pier or Belled pier Callout Tag
Fri, Jan 30, 2009 at 9:22:11 AM
Pier Callout
Sat, Mar 17, 2007 at 8:17:15 PM
How to model this pier head?
Thu, Jun 13, 2013 at 8:32:04 PM
Page generation time: 2.0480
