17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> WALL CUT (openings) MATERIAL
5 Posts No Rating |
hi all,
I there is an image at all the wall openings (the brick ones at the windows and doors) that I dont want. it looks looks asthough it was was the wall sweep image but when I change the wall sweep material it still stays the same. i have attached the image.
Thanks in advance!
It appears that someone painted the returns at your openings. These can be defined in the wall type.
Repaint those to default.
5 Posts No Rating |
thx. how do I do that?
7 Posts No Rating |
If you are using version 2013 or above, you can use the "Remove Paint" tool which is located within the paint tool under the modify tab. Remove the paint from the unwanted surfaces. If you are using 2012 or older, pick the paint tool and choose the <By Catagory> material and pick the surfaces that have the unwanted paint applied. Check out my Revit blog at bimeveryday.com
I hope this helps!
Revit blog: www.bimeveryday.com |
Wall Openings |
Mon, Mar 9, 2009 at 2:40:22 PM
Wall openings disappear when linked model is turned off |
Wed, Mar 16, 2016 at 1:00:24 PM
creating wall openings with void extrusions? |
Wed, Apr 8, 2009 at 4:51:59 AM
fascias should be able to be cut by vertical openings |
Fri, Oct 29, 2010 at 4:26:45 PM
component with material and recess wall |
Thu, Sep 10, 2015 at 7:22:23 AM
